[geos-devel] Exposing Precision model through C-API
Varun Saraf
varunsaraf14 at gmail.com
Mon Feb 17 02:23:29 PST 2014
I am not sure if I have understood the solution, but this is what I think.
For exposing PrecisionModel through the C-API, we need to write a function
in the geos_ts_c.cpp file which takes the required arguments for the
precision model. It constructs a new GeometryFactory with appropriate
arguments which in turn calls PrecisionModel with those arguments.
My doubt is what all arguments need to be passed to this C-API function and
is that what we are supposed to design. Also we will have to make
appropriate changes to the GeometryFactory constructor.
Please tell me if I am in the right direction.
Regards,
Varun Saraf
On Fri, Feb 14, 2014 at 7:08 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Thu, Feb 13, 2014 at 07:19:49PM +0100, Sandro Santilli wrote:
> > On Thu, Feb 13, 2014 at 05:25:17PM +0530, Anubhav Jaiswal wrote:
> > > Hi,
> > > Just wanted to know whether GEOS is applying for GSoC'14 under OSGeo.
> If
> > > yes, will this(exposing precision model) be a sufficient task or are
> there
> > > any other project ideas for GSoC.
> > I'm available for mentoring such a project, which I find sufficient.
> > There might be some GSoC ideas wiki page but I don't know right away.
> Hamish pointed me here:
> http://trac.osgeo.org/geos/wiki/GSoC
> It seems to be the place were 2014 ideas would be put.
> Anubhav, are you willing to write down the precision model idea ?
> --strk;
> () ASCII ribbon campaign -- Keep it simple !
> /\ http://strk.keybit.net/rants/ascii_mails.txt
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20140217/fe820aee/attachment.html>
