[geos-devel] Splitting _r and non _r functions in 2 different .h ?
Sandro Santilli
strk at keybit.net
Fri Jun 20 00:55:32 PDT 2014
Please also take a look at this pending pull request for
the re-entrant API: https://github.com/libgeos/libgeos/pull/26
It's blocked on naming, for the same reason you're doing this work
(avoiding confusion)
--strk;
On Wed, Jun 18, 2014 at 06:52:58PM +0200, Sandro Santilli wrote:
> On Wed, Jun 18, 2014 at 06:32:25PM +0200, Even Rouault wrote:
> > I've hit an integration problem with QGIS using the non _r API and spatialite
> > calling (accidently) finishGEOS() when closing a spatialite DB, causing later
> > crashes in QGIS.
> > So I've converted all the QGIS calls to GEOS to the _r API, and to do that the
> > easiest solution was to alter geos_c.h to remove the non _r symbols and fix all
> > compilation problems. But to make that robust in the length, it would be good
> > to be upstreamed.
> > GDAL and MapServer also now use the _r API for similar reasons. And it would
> > also be good to be sure noone reintroduce calls to the non _r API.
> I was actually thinking to deprecate the non _r API at some point,
> but I've been too lazy to port PostGIS to the _r ones so far, so
> I keep adding the non _r ones even for new signature :/
> --strk;
