[geos-devel] GEOSNode usage: what should g be?
Roger Bivand Roger.Bivand at nhh.no
Sun Mar 23 02:41:31 PDT 2014
Answering my own question, g can be LineString and GeometryCollection, I
haven't tested MultiLineString. The returned objects are MultiLineString.
Testing with the original problem (a twisted bowtie polygon coerced to
LineString), with a 2D rectangular random walk with 999 segments, and 100
random segments shows no issues, with the noded output feeding through to
polygonizing without obvious failures.
Roger
Roger Bivand wrote
> I'd like to ask for pointers to example code using GEOSNode/GEOSNode_r in
> CAPI. What should the geometry g be - GEOS_MULTILINESTRING,
> GEOS_LINESTRING, or what? Looking at the C++ code, it appears to be a
> SegmentString. If so, can a GEOS_MULTILINESTRING be converted to such an
> object in the CAPI?
> I'd like to add noding to rgeos, a user has occasional incoming polygon
> geometries that are not valid, and whose creation he does not control, and
> needs to node them after coercion to line strings, before going back out
> through polygonize.
> Grateful for any ideas,
> Roger
> Roger Bivand
> Department of Economics, Norwegian School of Economics,
> Helleveien 30, N-5045 Bergen, Norway.
> voice: +47 55 95 93 55; fax +47 55 95 91 00
> e-mail:
> Roger.Bivand@
> geos-devel mailing list
> geos-devel at .osgeo
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Roger Bivand
NHH Norwegian School of Economics, Bergen, Norway
View this message in context: http://osgeo-org.1560.x6.nabble.com/GEOSNode-usage-what-should-g-be-tp5130497p5130512.html
Sent from the GEOS Developers mailing list archive at Nabble.com.
