[geos-devel] MinGW build of Geos on Win7
Sandro Santilli strk at keybit.net
Tue Nov 4 01:13:05 PST 2014
On Tue, Nov 04, 2014 at 11:02:04AM +0200, Theuns Heydenrych wrote:
> The problem is the ' after the
> -L/c/mingw491/prerequisites/i686-w64-mingw32-static/lib' , library path.
> I can go and fix it manually every time, but how can the makefile be fixed,
> so that this ' is not appended to the end of this path?
You'll have to try figuring out how it gets that value.
Are you configuring with the autotools or cmake build scripts ?
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
