[geos-devel] MinGW build of Geos on Win7
Theuns Heydenrych
theunsheydenrych at gmail.com
Tue Nov 4 01:36:40 PST 2014
Thanks, for the quick reply.
I am configuring with the autotools.
I generate the make files with ./configure
I think somewhere in the configure script, it adds the ' to the search path
, but how to debug and search for where this happens, i am afraid i dont
know.
I am using MinGW 4.9.1
On Tue, Nov 4, 2014 at 11:13 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Tue, Nov 04, 2014 at 11:02:04AM +0200, Theuns Heydenrych wrote:
> > The problem is the ' after the
> > -L/c/mingw491/prerequisites/i686-w64-mingw32-static/lib' , library path.
> > I can go and fix it manually every time, but how can the makefile be
> fixed,
> > so that this ' is not appended to the end of this path?
> You'll have to try figuring out how it gets that value.
> Are you configuring with the autotools or cmake build scripts ?
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20141104/a3fa0e5d/attachment.html>
