[geos-devel] MinGW build of Geos on Win7
Sandro Santilli strk at keybit.net
Tue Nov 4 02:18:19 PST 2014
On Tue, Nov 04, 2014 at 12:10:32PM +0200, Theuns Heydenrych wrote:
> Thanks Sandro
> I did run the commands you suggested and yes,
> "prerequisites/i686-w64-mingw32-static"
> appear in the output.
> It also appear with the extra ' in the output, like  prerequisites/i686-w64-
> mingw32-static/lib'
> How do i fix this?
> Here is the grep result.
> $ grep prerequisites/i686-w64-mingw32-static debug.log
> + test '-L/c/mingw491/prerequisites/i686-w64-mingw32-static/lib'\''' = -L
Check higher in the output, where did this value come from ?
You might need to reference the output to some .m4 input which could
be on your system (somewhere in autoconf install dir) and would sound
broken.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
