[geos-devel] [GEOS] #702: OverlayOp takes mover 20 minutes when a polygon with over a million holes is involved
geos-trac at osgeo.org
Tue Sep 9 04:22:39 PDT 2014
is involved
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.4.3
Component: Default | Version: 3.4.2
Severity: Unassigned | Keywords:
I've been looking at a huge polygon having over a million small holes and
a large extent, and saw ST_Intersection between it and a rectangle take
around 26 minutes.
Implementing a quick short-circuit based on analyzing each hole in turn
for it being in-or-out of the rectangle can take the time down to 5
seconds.
As of the new rectangle intersection optimization code (#699) I've seen
the same intersection take around 1 second.
This ticket is to find out if there's anything that could be optimized in
GeometryGraph building with these kind of inputs.
Ticket URL: <http://trac.osgeo.org/geos/ticket/702>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
