[geos-devel] Geometry/Rectangle Intersection, line merging ?
Mika Heiskanen
mika.heiskanen at fmi.fi
Tue Sep 9 05:00:44 PDT 2014
On 09/09/2014 01:48 PM, Sandro Santilli wrote:
> RE: rectangle intersection (#699)
> I've plugged the leak and compared the result of Geometry::intersection()
> and RectangleIntersection. One difference is about the linemerge operation
> happening in the RectangleIntersection class, that is a line going outside
> and then back inside the clipping rectangle gets merged by
> RectangleIntersection while it is not by standard intersection.
> The tests you provided expect the merging to happen, so if I drop the merging
> those tests are going to fail. What's the rationale for that additional
> operation ?
I assume you are referring to these comments:
* Sample clip with a rectangle 0,0 --> 10,10 without reconnecting:
* Input: POLYGON ((5 10,0 0,10 0,5 10))
* Output: MULTILINESTRING ((5 10,0 0),(10 0,5 10))
* Desired: LINESTRING (10 0,5 10,0 0)
If you recall, we wrote the algorithm for rendering. In this case if we
do not reconnect the two linestrings line-join behaviour will be broken
during rendering.
Regards,
Mika Heiskanen / FMI
