[geos-devel] libgeos BufferOp gives TopologyException “depth mismatch”
Alex Flint
alex.flint at gmail.com
Tue Sep 23 06:33:55 PDT 2014
I am working with the c++ interface to geos 3.4.2 on OSX (installed via
homebrew with --c++11).
I have created a LineString containing a CoordinateSequence of length 382
and then I run a buffer operation using:
geos::operation::buffer::BufferParameters buffer_params;
geos::operation::buffer::BufferOp buffer_op(input, buffer_params);
geos::geom::Geometry* output = buffer_op.getResultGeometry(1.5);
This throws a geos::geom::TopologyException with message:
depth mismatch at at -6 -10.5
I have searched quite a bit for this error message but I have not found
anything about what "depth mismatch" actually means. What does this error
mean and what can I do about it?
The 382 points in my coordinate sequence are here:
https://gist.github.com/alexflint/dcea786628af3b43d21a
Thanks!
Alex
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20140923/2f3154d9/attachment.html>
