[geos-devel] [GEOS] #699: Optimize Geometry->Intersection with rectangular argument
geos-trac at osgeo.org
Thu Sep 25 03:48:50 PDT 2014
Reporter: strk | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: major | Milestone: 3.5.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Changes (by strk):
* version: 3.4.2 => svn-trunk
* milestone: 3.4.3 => 3.5.0
Comment:
As of r4021 the RectangleIntersection class and a GEOSClipByRect C-API
function are in trunk (for 3.5.0). I've reverted the algorithm to the
initial one, just adding the CCW/CW handling.
The function will not attempt to handle precision model nor to ensure a
valid output, nor to retain boundary points. But it will be fast.
Adding the PHP binding of it would be nice, before closing this ticket.
Ticket URL: <http://trac.osgeo.org/geos/ticket/699#comment:13>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
