[geos-devel] [GEOS] #707: WKBReader does not read geometries with Z, M or ZM outside of Point
geos-trac at osgeo.org
Fri Sep 26 18:55:13 PDT 2014
Reporter: benmorel | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.4.3
Component: Default | Version: svn-trunk
Severity: Critical | Keywords: WKBReader
Comment(by mwtoews):
This is a duplicate of #466
The example geometry is ISO WKB. GEOS currently only supports EWKB,
defined by PostGIS (however, PostGIS seamlessly supports both ISO WKB and
EWKB formats).
The EWKB equivalent of the example linestring is:
0102000080030000000000000000000000000000000000F03F0000000000000040000000000000F03F00000000000000400000000000000840000000000000004000000000000008400000000000001040
But yeah, I agree it would be nice to have GEOS catch up to the abilities
of PostGIS.
Ticket URL: <http://trac.osgeo.org/geos/ticket/707#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
