[geos-devel] [GEOS] #707: WKBReader does not read geometries with Z, M or ZM outside of Point
GEOS geos-trac at osgeo.org
Sat Sep 27 05:26:38 PDT 2014
 Reporter:  benmorel  |       Owner:  geos-devel@…
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  3.4.3
Component:  Default   |     Version:  svn-trunk
 Severity:  Critical  |    Keywords:  WKBReader
Comment(by benmorel):
 Thanks, I did not think one second that GEOS would not be able to handle
 ISO WKB. I'll see if I can make changes to the WKBReader so that it can
 handle WKB as well: any WKB being valid EWKB, it should be possible
 without breaking anything.
Ticket URL: <http://trac.osgeo.org/geos/ticket/707#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
