[geos-devel] [GEOS] #760: Snapping leaves segments below tolerance
geos-trac at osgeo.org
Tue Dec 29 09:21:34 PST 2015
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.5.1
Component: Default | Version: 3.5.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
I shell note the problem is dependent on order of vertices in the target
point set.
Here's a simpler input:
src: LINESTRING(0 0,0 20)
tgt: LINESTRING(0.5 19,1 18,1.5 17)
Take the target in the given order and snapping is final after first
iteration.
Reverse the target and it takes 3 iterations to fully snap:
SELECT
0.8 as tol,
'LINESTRING(0 0,0 20)'
::geometry as src,
'LINESTRING(0.5 19,1 18,1.5 17)'
::geometry as tgt
SELECT
ST_AsText(src) src,
ST_AsText(ST_Snap(src , tgt , tol)) snap1,
ST_AsText(ST_Snap(ST_Snap(src , tgt , tol), tgt, tol)) snap2,
ST_AsText(ST_Snap(ST_Snap(ST_Snap(src , tgt , tol), tgt, tol), tgt, tol))
snap3,
ST_AsText(ST_Snap(src , ST_Reverse(tgt) , tol)) snap1r,
ST_AsText(ST_Snap(ST_Snap(src , ST_Reverse(tgt) , tol), ST_Reverse(tgt),
tol)) snap2r,
ST_AsText(ST_Snap(ST_Snap(ST_Snap(src , ST_Reverse(tgt) , tol),
ST_Reverse(tgt), tol), ST_Reverse(tgt), tol)) snap3r,
ST_Distance(src, ST_EndPoint(tgt)) dist_end,
ST_Distance(src, ST_StartPoint(tgt)) dist_start,
ST_Distance(src, ST_PointN(tgt,2)) dist_p2,
ST_Distance(src, ST_PointN(tgt,3)) dist_p3
FROM inp;
-[ RECORD 1 ]---------------------------------------
src | LINESTRING(0 0,0 20)
snap1 | LINESTRING(0 0,1.5 17,1 18,0.5 19,0 20)
snap2 | LINESTRING(0 0,1.5 17,1 18,0.5 19,0 20)
snap3 | LINESTRING(0 0,1.5 17,1 18,0.5 19,0 20)
snap1r | LINESTRING(0 0,0.5 19,0 20)
snap2r | LINESTRING(0 0,1 18,0.5 19,0 20)
snap3r | LINESTRING(0 0,1.5 17,1 18,0.5 19,0 20)
dist_end | 1.5
dist_start | 0.5
dist_p2 | 1
dist_p3 | 1.5
Ticket URL: <https://trac.osgeo.org/geos/ticket/760#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
