[geos-devel] [GEOS] #753: cannot build geos 3.5.0
GEOS geos-trac at osgeo.org
Tue Nov 3 05:18:30 PST 2015
 Reporter:  rashadkm    |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.5.1
Component:  Default     |     Version:  3.5.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by mloskot):
 No. First you need to check it out or just download CMakeLists.txt
 (https://trac.osgeo.org/geos/browser/trunk/CMakeLists.txt?rev=4112&format=txt),
 and test if solution works for you. Once you have tested it and confirmed
 it's sound, the package may be updated.
Ticket URL: <https://trac.osgeo.org/geos/ticket/753#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
