[geos-devel] [GEOS] #753: cannot build geos 3.5.0
geos-trac at osgeo.org
Tue Nov 3 10:16:23 PST 2015
Reporter: rashadkm | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.5.1
Component: Default | Version: 3.5.0
Severity: Unassigned | Resolution: fixed
Keywords: |
Comment (by rashadkm):
Replying to [comment:4 mloskot]:
> No. First you need to check it out or just download CMakeLists.txt
(https://trac.osgeo.org/geos/browser/trunk/CMakeLists.txt?rev=4112&format=txt),
and test if solution works for you. Once you have tested it and confirmed
it's sound, the package may be updated.
okay. seems fair. I will test it tomorrow and update to you.
Ticket URL: <https://trac.osgeo.org/geos/ticket/753#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
