[geos-devel] updating geos 3.5.0 source archive.
Rashad M
mohammedrashadkm at gmail.com
Sun Nov 8 13:01:53 PST 2015
On Sun, Nov 8, 2015 at 4:39 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Rashad,
> On Sun, 08. Nov 2015 at 01:43:52 +0100, Rashad M wrote:
> > could this be changed in OSGeo4W for geos? can we have geos c++ api in
> > osgeo4w.? I think the discussion regarding osgeo4w could be move to other
> > list.
> For which compiler(s)?
MSVC 2012. Does that matter much since ossim uses geos c++ api ?
> > I have ticket on osgeo4w trac for updating goes.
> That's where I asked if it's possible to port OSSIM to the (recommended)
> C-API.
> From a quick look only oms/coms/src/oms/DataInfo.cpp and
> ossim/src/ossim/base/ossimPolyArea2d.cpp use GEOS.
> IIRC, ossim said it will stick to c++api as long as there is one. I know
GEOS recommends to use C-API but it also provides c++. So I don't see that
ossim is going to move away.
> But I see the precision model there...
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20151108/16a2fc54/attachment.html>
