[geos-devel] updating geos 3.5.0 source archive.
Rashad M mohammedrashadkm at gmail.com
Sun Nov 8 13:02:57 PST 2015
Hello Jurgen,
You haven't said if including geos c++ api is okay for osgeo4w ?
On Sun, Nov 8, 2015 at 10:01 PM, Rashad M <mohammedrashadkm at gmail.com>
wrote:
> On Sun, Nov 8, 2015 at 4:39 PM, Jürgen E. <jef at norbit.de> wrote:
>> Hi Rashad,
>> On Sun, 08. Nov 2015 at 01:43:52 +0100, Rashad M wrote:
>> > could this be changed in OSGeo4W for geos? can we have geos c++ api in
>> > osgeo4w.? I think the discussion regarding osgeo4w could be move to
>> other
>> > list.
>> For which compiler(s)?
> MSVC 2012. Does that matter much since ossim uses geos c++ api ?
>> > I have ticket on osgeo4w trac for updating goes.
>> That's where I asked if it's possible to port OSSIM to the (recommended)
>> C-API.
>> From a quick look only oms/coms/src/oms/DataInfo.cpp and
>> ossim/src/ossim/base/ossimPolyArea2d.cpp use GEOS.
>> IIRC, ossim said it will stick to c++api as long as there is one. I know
> GEOS recommends to use C-API but it also provides c++. So I don't see that
> ossim is going to move away.
>> But I see the precision model there...
>> Jürgen
>> Jürgen E. Fischer         norBIT GmbH               Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
>> +49-4931-918175-50
>> Software Engineer         D-26506 Norden
>> http://www.norbit.de
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
> Regards,
>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20151108/c2ecf206/attachment.html>
