[geos-devel] updating geos 3.5.0 source archive.
Jürgen E. Fischer jef at norbit.de
Mon Nov 9 16:42:41 PST 2015
Hi Rashad,
On Sun, 08. Nov 2015 at 22:01:53 +0100, Rashad M wrote:
> > For which compiler(s)?
> MSVC 2012. Does that matter much since ossim uses geos c++ api ?
Yes, only because ossim is using the c++ api.
> > IIRC, ossim said it will stick to c++api as long as there is one. I know
> GEOS recommends to use C-API but it also provides c++. So I don't see that
> ossim is going to move away.
Why not?  Other projects have to.  I'd prefer to keep the C++ API out
of the picture.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20151110/7f6c9d25/attachment.sig>
