[geos-devel] [GEOS] #741: GEOSSimplify() returns empty polygon if inner ring dimension < simplify distance
GEOS geos-trac at osgeo.org
Mon Sep 21 01:04:14 PDT 2015
distance
 Reporter:  rouault     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.3
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by strk):
 Martin, can you check if this also happens in JTS?
Ticket URL: <https://trac.osgeo.org/geos/ticket/741#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
