[geos-devel] Intersection Polygon/Polygon curiosity
Roger Bivand Roger.Bivand at nhh.no
Fri Sep 25 11:03:02 PDT 2015
An oddity has shown up when a toy example is run in R/rgeos and Shapely
when two polygon geometrycollections are intersected; thread at:
https://stat.ethz.ch/pipermail/r-sig-geo/2015-September/023468.html
With the data as input, GEOSIntersection_r returns the first object
instead of the intersection. When the coordinates are multiplied by 5, it
fails with TopologyException: no outgoing dirEdge found ...
Here is the Shapely case (GEOS 3.5.0):
from shapely.wkt import dumps, loads
MyLay = loads("GEOMETRYCOLLECTION (POLYGON ((0.0000000000000000
0.0000000000000000, 0.0000000000000000 1.0000000000000000,
1.0000000000000000 1.0000000000000000, 1.0000000000000000
0.0000000000000000, 0.0000000000000000 0.0000000000000000)), POLYGON
((0.0000000000000000 0.0000000000000000, 1.0000000000000000
0.0000000000000000, 1.0000000000000000 -1.0000000000000000,
0.0000000000000000 -1.0000000000000000, 0.0000000000000000
0.0000000000000000)))")
MyLayl = loads("GEOMETRYCOLLECTION (POLYGON ((0.1000000000000000
0.1000000000000000, 0.1000000000000000 1.1000000000000001,
1.1000000000000001 1.1000000000000001, 1.1000000000000001
0.1000000000000000, 0.1000000000000000 0.1000000000000000)), POLYGON
((0.1000000000000000 0.1000000000000000, 1.1000000000000001
0.1000000000000000, 1.1000000000000001 -0.9000000000000000,
0.1000000000000000 -0.9000000000000000, 0.1000000000000000
0.1000000000000000)))")
merged = MyLay.intersection(MyLayl)
dumps(merged)
'POLYGON ((0.0000000000000000 0.0000000000000000, 0.0000000000000000
1.0000000000000000, 1.0000000000000000 1.0000000000000000,
1.0000000000000000 0.0000000000000000, 1.0000000000000000
-1.0000000000000000, 0.0000000000000000 -1.0000000000000000,
0.0000000000000000 0.0000000000000000))'
merged.equals(MyLay)
True
in R (GEOS 3.5.0):
library(sp)
library(rgeos)
Pol1=rbind(c(0,0),c(0,1),c(1,1),c(1,0),c(0,0))
Pol2=rbind(c(0,0),c(1,0),c(1,-1),c(0,-1),c(0,0))
Pols1=Polygons(list(Polygon(Pol1)),"Pols1")
Pols2=Polygons(list(Polygon(Pol2)),"Pols2")
MyLay=SpatialPolygons(list(Pols1,Pols2))
Pol1l=Pol1+0.1
Pol2l=Pol2+0.1
Pols1l=Polygons(list(Polygon(Pol1l)),"Pols1l")
Pols2l=Polygons(list(Polygon(Pol2l)),"Pols2l")
MyLayl=SpatialPolygons(list(Pols1l,Pols2l))
inter=gIntersection(MyLay,MyLayl)
gEquals(inter, MyLay)
plot(MyLay)
plot(MyLayl,add=TRUE)
plot(inter,col="red",add=TRUE)
writeWKT(MyLay)
writeWKT(MyLayl)
There is a report on the thread of PostGIS not showing the issue, but we
are checking that the same input data are being used.
Grateful for any input correcting my misunderstanding ...
Roger
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
