[geos-devel] [GEOS] #713: [Patch] Add GeometryPrecisionReducer to C API
GEOS geos-trac at osgeo.org
Wed Sep 30 08:55:02 PDT 2015
 Reporter:  smani       |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.3
Component:  Default     |     Version:  3.4.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by strk):
 Sandro: is there an updated patch, or pull request, with the outcome of
 the discussion on the list ?
 I understand you're now using a C wrapper in QGIS to use that
 functionality, are there tests showing how using the precision reduction
 code worked with overlay operations ?
Ticket URL: <https://trac.osgeo.org/geos/ticket/713#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
