[geos-devel] [GEOS] #713: [Patch] Add GeometryPrecisionReducer to C API
geos-trac at osgeo.org
Wed Sep 30 11:18:53 PDT 2015
Reporter: smani | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.4.3
Component: Default | Version: 3.4.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by smani):
Right, 1:1 was more like 1:1 of the functionality I needed.
It's been a while since I did the original experiments, but I think the
important thing was that the actual precision model of the geometries
changed in order to have the analysis operations run with that precision
model.
Ultimately what I needed was a way to reduce the chance of getting these
tiny spikes caused by imprecisions when for instance intersecting
geometries, or cases where unions of neighboring geometries failed due to
geos thinking they were disjoint (again due to precision issues).
I agree that having QGIS link agains the entire C++ GEOS library is an
overkill, but at present it was the only way to get it merged into master.
As soon as GEOS offers such functionality in the C library I'm happy to
port the QGIS code to whatever API ultimately is implemented and remove
the dependency again.
Ticket URL: <https://trac.osgeo.org/geos/ticket/713#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
