[geos-devel] [GEOS] #713: [Patch] Add GeometryPrecisionReducer to C API
GEOS geos-trac at osgeo.org
Wed Sep 30 11:34:42 PDT 2015
 Reporter:  smani       |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.3
Component:  Default     |     Version:  3.4.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by strk):
 What I'm saying is that from what I can read in code, I don't think you
 are having analisys operation run with the custom precision model. A test
 showing they are would be useful, but I found no test under QGIS.
 Such a test would use input geometries that produce the _same_ coordinate
 values (same HEXWKB) after coming out from PrecisionReducer but produce
 spikes (or other issues) when passed directly to those analisys operation
 and do not produce them when passed after the PrecisionReduced threatment.
Ticket URL: <https://trac.osgeo.org/geos/ticket/713#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
