[geos-devel] [GEOS] #713: [Patch] Add GeometryPrecisionReducer to C API
GEOS geos-trac at osgeo.org
Wed Sep 30 13:07:14 PDT 2015
 Reporter:  smani       |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.3
Component:  Default     |     Version:  3.4.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by smani):
 If I recall correctly the reduce operation returns a geometry with a
 corresponding precision model. And I thought this to be sufficient to have
 the analysis operation run in reduced precision mode?
 I'll see whether I can dig up my test geometries again and produce a test.
 But I definitely recall seeing a difference with and without the reduce
 operation.
Ticket URL: <https://trac.osgeo.org/geos/ticket/713#comment:11>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
