[geos-devel] Extraction of PHP extension into PECL-style package
Sandro Santilli
strk at keybit.net
Thu Jan 28 00:49:27 PST 2016
Great work, thanks!
The branch was merged to master and pushed to
git://git.osgeo.org/php-geos
Supposedly, this should result in the github and gitlab mirrors
to be updated shortly.
NOTE: I've added an ./autogen.sh call so things sound familiar.
I guess next stop would be having a "make check" in place,
and then enabling build bots on github/gitlab (and possibly
also jenkins, if Regina wants to help there).
--strk;
On Mon, Jan 25, 2016 at 06:24:00PM -0500, J Smith wrote:
> Quick update on the PHP extraction folks...
> I've pushed a first pass to
> https://github.com/libgeos/php-geos/tree/phpize . This branch contains
> the following:
> - build files that work with the phpize command.
> - PECL/PEAR-style packaging files.
> - geos.c has been updated to use #ifdefs to work with GEOS features as
> detected by configure. This allows a single PHP extension to handle
> versions of GEOS from 3.3 right up to the current svn trunk. The tests
> have likewise been modified to skip any features not found in the
> current library version, although they haven't been re-written to
> accommodate missing features used directly in testing, like
> setRoundingPrecision and setTrim and the like. Those features could
> perhaps be emulated for the sake of testing, but as it is, they are
> currently not working. Note that 3.2 isn't working yet, as it relies
> on some more recent features like GEOSBufferParams which would need to
> be emulated or otherwise avoided altogether to compile. When I have
> time I'll look into this. For ffi-geos, I basically emulated the
> options hash interface if GEOSBufferParams didn't exist in the library
> being used, so that could likely be done here.
> - I noticed in the TODO file an entry for "Use the re-entrant C-API
> interface" so I've switched over to that using PHP's thread safe
> runtime manager. I haven't had an opportunity to test this out yet in
> a multithreaded environment, just on the CLI, but the code runs and
> the tests all pass for that particular target.
> That's all for now. Cheers.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
