[geos-devel] [GEOS] #777: SVN version won't build on Windows
    geos-trac at osgeo.org
    Tue May  3 06:00:48 PDT 2016
 Reporter:  jluis       |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.5.1
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by strk):
 Probably a missing file in the vc build scripts,
 but nobody likes windows so nobody cares to maintain
 those scripts. If you send a patch, it could be applied.
Ticket URL: <https://trac.osgeo.org/geos/ticket/777#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
