[geos-devel] [GEOS] #777: SVN version won't build on Windows
geos-trac at osgeo.org
Tue May 3 05:56:23 PDT 2016
Reporter: jluis | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.5.1
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
It errors with
[ 81%] Building CXX object capi/CMakeFiles/geos_c.dir/geos_c.cpp.obj
geos_c.cpp
V:\geos_SVN\build\capi\geos_c.h(826) : error C2059: syntax error :
'__declspec(dllexport)'
V:\geos_SVN\build\capi\geos_c.h(831) : error C2059: syntax error :
V:\geos_SVN\build\capi\geos_c.h(1746) : error C2059: syntax error :
V:\geos_SVN\build\capi\geos_c.h(1764) : error C2059: syntax error :
V:\geos_SVN\capi\geos_c.cpp(1165) : error C3861:
'GEOSSTRtree_nearest_generic': identifier not found
V:\geos_SVN\capi\geos_c.cpp(1174) : error C3861:
'GEOSSTRtree_nearest_generic_r': identifier not found
NMAKE : fatal error U1077: 'C:\PROGRA~2\MICROS~3.0\VC\bin\cl.exe' : return
code '0x2'
Ticket URL: <https://trac.osgeo.org/geos/ticket/777>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
