[geos-devel] Extraction of PHP extension into PECL-style package
Sandro Santilli
strk at keybit.net
Mon May 2 08:08:04 PDT 2016
Thanks for the update, J
Let me know when you need some testing
--strk;
On Mon, May 02, 2016 at 10:32:17AM -0400, J Smith wrote:
> G'day list.
> Just a quick update on the GEOS PHP bindings. I took some time last
> night to take a look at PHP 7 and did a quick migration to their new
> API. I'm able to compile cleanly and some of the tests are running,
> although I need to sort through the individual methods and clean up
> some bits and pieces here and there. Most of the pain at this point
> involves changes to the way PHP 7 manages memory and moving over to
> new data types like zend_string where it makes sense. It's definitely
> a decent start, even if it's a bit rough at the moment. Once I get
> everything stabilized I'll look into abstracting some of the changes
> away into some macros and the like so that both PHP 5 and 7 can
> compile from the same code base, as right now I've torn things apart
> for the sake of getting to know PHP 7 a bit better. The major hang up
> at the moment is the new memory management system, as I'm experiencing
> segfaults at process shutdown and with garbage collection, but it's
> nothing that's insurmountable, just some basic refactoring and
> rejiggering that's necessary. I'll have some more time available soon
> to try and wrap up a first pass, after which the abstractions will
> come in.
> Cheers, list.
> On Mon, Mar 21, 2016 at 5:15 AM, Sandro Santilli <strk at keybit.net> wrote:
> > On Sun, Mar 20, 2016 at 07:48:46PM -0400, J Smith wrote:
> >> On Thu, Mar 10, 2016 at 5:02 PM, Sandro Santilli <strk at keybit.net> wrote:
> >> > Also, the "make check" run ends with prompting me, which is really
> >> > annoying. The prompt asks if I want to send the report to the PHP QA
> >> > team. Really ? Should we send successful test run reports for a single
> >> > package to "the PHP QA team" ?? I wouldn't want to be in that team :)
> >> Yeah, that's annoying. All part of the standard test suite for PECL
> >> extensions. :/
> >> How about this...
> >> - I'll make the tests spit out more output on success so we know
> >> things are working fine. Likewise when there's a problem, it'll be
> >> more obvious what failed.
> > I actually like the output to be short and clean on success
> > (just a short report of how many tests were run). This wasn't
> > the case IIRC.
> > Can't comment on the quality of failure reports as if I understood
> > correctly there was no failure in my run.
> >> - I'll see what I can do about `make check`, have it not prompt
> >> anything. I'll leave `make test` as-is because that's the standard
> >> PECL testing command and there might be some dependencies on it
> >> behaving that way, but `make check` shouldn't have any similar
> >> dependencies since it's an OSGEO-thing I assume, right?
> > 'make check' can be just an alias for 'make note'.
> >> On another note, I'll be looking into PHP7 compatibility. I took an
> >> initial look about a month ago, doesn't look too bad, but it'll take
> >> it some time I figure.
> > Great, thanks !
> > --strk;
