[geos-devel] GEOS-3.6.0 released
Sebastiaan Couwenberg sebastic at xs4all.nl
Tue Oct 25 12:47:13 PDT 2016
On 10/25/2016 09:43 PM, Jeff McKenna wrote:
> On 2016-10-25 4:23 PM, Sebastiaan Couwenberg wrote:
>> On 10/25/2016 06:07 PM, Sandro Santilli wrote:
>>>   - C++ API changes:
>>>     - Automatic memory management for GeometryFactory objects
>> This change seems to cause the build failures for OSSIM, osmium &
>> osm2pgsql with GEOS 3.6.0. All three builds fail with these errors:
>>  'geos::geom::GeometryFactory::GeometryFactory()' is protected within
>> this context
>>  'virtual geos::geom::GeometryFactory::~GeometryFactory()' is protected
>> within this context
>> What is the proper way to support GeometryFactory for both GEOS 3.5.0
>> and 3.6.0?
> Bas I was also confused (as a packager) seeing these 2 releases come
> out, and not sure how all of the many other projects handle the 3.6.0
> changes (like GDAL, MapServer, PostGIS etc.).  So I'm assuming that
> packagers like us Bas are to use 3.5.1 for now?
3.5.1 seems to be the safer choice for now, although I haven't tested
the reverse dependencies with that yet (still working through all of
them with 3.6.0).
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
