[geos-devel] [GEOS] #753: cannot build geos 3.5.0
GEOS geos-trac at osgeo.org
Sat Apr 8 09:22:43 PDT 2017
 Reporter:  rashadkm    |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.5.1
Component:  Default     |     Version:  3.5.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by Mateusz Loskot <mateusz@…>):
 In [changeset:"c1682daa78f2ab33c374572de98059b0b62027c7/git"
 c1682daa/git]:
 #!CommitTicketReference repository="git"
 revision="c1682daa78f2ab33c374572de98059b0b62027c7"
 CMake should not try to generate geos_svn_revision.h if GEOS is built from
 packaged sources.
 Fixes #753
 git-svn-id: http://svn.osgeo.org/geos/trunk@4112 5242fede-
 7e19-0410-aef8-94bd7d2200fb
Ticket URL: <https://trac.osgeo.org/geos/ticket/753#comment:13>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
