[geos-devel] [GEOS] #753: cannot build geos 3.5.0
geos-trac at osgeo.org
Sat Apr 8 09:34:04 PDT 2017
Reporter: rashadkm | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.5.1
Component: Default | Version: 3.5.0
Severity: Unassigned | Resolution: fixed
Keywords: |
Comment (by Mateusz Loskot <mateusz@…>):
In [changeset:"c1682daa78f2ab33c374572de98059b0b62027c7/git"
c1682daa/git]:
#!CommitTicketReference repository="git"
revision="c1682daa78f2ab33c374572de98059b0b62027c7"
CMake should not try to generate geos_svn_revision.h if GEOS is built from
packaged sources.
Fixes #753
git-svn-id: http://svn.osgeo.org/geos/trunk@4112 5242fede-
7e19-0410-aef8-94bd7d2200fb
Ticket URL: <https://trac.osgeo.org/geos/ticket/753#comment:14>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
