[geos-devel] [GEOS] #828: Change debbie to use gogs webhook instead of polling
GEOS geos-trac at osgeo.org
Mon Apr 10 08:33:47 PDT 2017
 Reporter:  robe        |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:  3.7.0
Component:  Default     |    Version:  svn-trunk
 Severity:  Unassigned  |   Keywords:
 strk,
 Now that GEOS is on gogs and  we have gogs webhook installed on debbie's
 jenkins,  can we as a firs step, change GEOS jobs to use Gogs web hook.
 Right now it's using polling for running the jobs.
 If that passes, then we can with PostGIS and GEOS investigate testing pull
 requests as well.
 I'm not sure how web-hooks are setup on Gogs so not sure where to start.
Ticket URL: <https://trac.osgeo.org/geos/ticket/828>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
