[geos-devel] [GEOS] #828: Change debbie to use gogs webhook instead of polling
geos-trac at osgeo.org
Mon Apr 10 08:41:19 PDT 2017
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Resolution:
Keywords: |
Comment (by dbaston):
I actually like 5min polling....helps in the odd case where you forget to
add a new file and then commit again right away.
Ticket URL: <https://trac.osgeo.org/geos/ticket/828#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
