[geos-devel] [GEOS] #828: Change debbie to use gogs webhook instead of polling
GEOS geos-trac at osgeo.org
Mon Apr 10 08:48:38 PDT 2017
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.7.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by strk):
 To account for the "forgot" case, my own mirroring script waits
 a configurable amount of seconds before starting the mirroring
 process, maybe the jenkins build configuration allows for something
 like that too ? I know for sure Buildbot did have support for that
 kind of building (ie: not all commits, but at a minimum time distance).
 Anyway, it's also useful to test each and every commit
 (and reduce the number of commits by running "make check" locally)
Ticket URL: <https://trac.osgeo.org/geos/ticket/828#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
