[geos-devel] [GEOS] #830: Possible memory leak in WKTReader with partial MULTIPOLYGON
geos-trac at osgeo.org
Wed Apr 12 06:01:48 PDT 2017
Reporter: goatbar | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone:
Component: Default | Version: 3.5.0
Severity: Unassigned | Resolution:
Keywords: wkt fuzzing |
Comment (by goatbar):
Sadly, no, https://github.com/OSGeo/geos/pull/83 does not fix the issue.
source:trunk/src/io/WKTReader.cpp at 4052#L422
`new vector' is leaked if there is a throw before return. I am not sure
what shape the fix should be. If this were C++11, putting it in a
unique_ptr would make sure it was deleted as the stack unwound. A closer
class with a delete in the destructor would work too. Or simplest might
be to try / catch the exception. I'm not very experienced with
exceptions, so I haven't tried catch the exception yet.
{{{#!c++
MultiPolygon* WKTReader::readMultiPolygonText(StringTokenizer *tokenizer)
string nextToken=getNextEmptyOrOpener(tokenizer);
if (nextToken=="EMPTY") {
return geometryFactory->createMultiPolygon(NULL);
vector<Geometry *> *polygons=new vector<Geometry *>(); // <---
This is leaked.
Polygon *polygon=readPolygonText(tokenizer);
polygons->push_back(polygon);
nextToken=getNextCloserOrComma(tokenizer);
while(nextToken==",") {
MultiPolygon *ret = geometryFactory->createMultiPolygon(polygons);
//for (int i=0; i<polygons->size(); i++) delete (*polygons)[i];
//delete polygons;
return ret;
I would guess that every other read method with a new will also leak.
Ticket URL: <https://trac.osgeo.org/geos/ticket/830#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
