[geos-devel] [GEOS] #830: Possible memory leak in WKTReader with partial MULTIPOLYGON
geos-trac at osgeo.org
Wed Apr 12 06:09:41 PDT 2017
Reporter: goatbar | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone:
Component: Default | Version: 3.5.0
Severity: Unassigned | Resolution:
Keywords: wkt fuzzing |
Comment (by mloskot):
Kurt, this is classic lack of RAII in GEOS which. Switch to C++11 should
help, replacing auto_ptr with unique_ptr and using unique_ptr in as many
places as possible.
In this particular case, `vector<Geometry *> *polygons=new vector<Geometry
*>(` could be replaced with intermediate vector on stack, once fully
created, allocate new on heap and move `polygons` data into it before
passing to `createMultiPolygon`.
This however is partial fix: it will avoid leaking `polygons = new
vector<Geometry *>` but won't avoid leaking heap-allocated items of
`polygons`.
Long term solution could be switching away from heap-allocated vectors to
use of rvalues with move semantic.
Ticket URL: <https://trac.osgeo.org/geos/ticket/830#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
