[geos-devel] GEOS-3.5.1 released
Marco Atzeri
marco.atzeri at gmail.com
Tue Jan 10 05:10:46 PST 2017
On 25/10/2016 18:38, Sandro Santilli wrote:
> Release 3.5.1 of GEOS is available:
> http://download.osgeo.org/geos/geos-3.5.1.tar.bz2
> MD5: 2e3e1ccbd42fee9ec427106b65e43dc0
> This is a bugfix release, containing these fixes/improvements:
> - Fix CMake configuration to allow build from released sources
> package (#753)
> - Fix memory leaks in single-sided buffers (#747), PlanarGraph and
> tests
> - Fix GeometryEditor to correctly update factory of empty geometries
> (#749)
> - Fix snapping of last segment of a closed linestring (#758)
> - Fix memory exhaustion case in isvalid (#757)
> - Fix Windows build with Visual Studio 2008 (#766)
> - Fix incorrect return from prepared multipoint intersects (#764)
> - Fix build against GCC 3.5.0+ (#784)
> Enjoy !
> --strk;
this release is causing on cygwin a share lib version bump from
cyggeos-3-5-0.dll to cyggeos-3-5-1.dll
As FIX only I do not see any change requiring it.
Is this assumption a bit too much ?
dnl -- Release versions / C++ library SONAME will use these
dnl -- encoding ABI break at every release
Regards
Marco
