[geos-devel] [GEOS] #694: PreparedPoint::intersects gives different results from Point::intersects
GEOS geos-trac at osgeo.org
Wed Jul 19 14:59:29 PDT 2017
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.6.2
Component:  Default     |     Version:  3.4.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"63410b14d1ca1117a91b2e31928d893cf78fa1fb/git" 63410b1/git]:
 #!CommitTicketReference repository="git"
 revision="63410b14d1ca1117a91b2e31928d893cf78fa1fb"
 Add support for testing prepared geometries operations in XMLTester
 Add 3 more tests from JTS testsuite now that they can be run
 See #694
Ticket URL: <https://trac.osgeo.org/geos/ticket/694#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
