[geos-devel] [GEOS] #694: PreparedPoint::intersects gives different results from Point::intersects
geos-trac at osgeo.org
Wed Jul 19 15:12:38 PDT 2017
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.6.2
Component: Default | Version: 3.4.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by Sandro Santilli <strk@…>):
In [changeset:"a12a5ecc5c8ccd41c5e4952bcb58d994e4d709e2/git" a12a5ec/git]:
#!CommitTicketReference repository="git"
revision="a12a5ecc5c8ccd41c5e4952bcb58d994e4d709e2"
Add support for testing prepared geometries operations in XMLTester
Add 3 more tests from JTS testsuite now that they can be run
See #694 for 3.6 branch
Ticket URL: <https://trac.osgeo.org/geos/ticket/694#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
