[geos-devel] [GEOS] #694: PreparedPoint::intersects gives different results from Point::intersects
GEOS geos-trac at osgeo.org
Wed Jul 19 15:18:42 PDT 2017
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  blocker     |   Milestone:  3.6.2
Component:  Default     |     Version:  3.4.2
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 It looks like  r3988 was re-committed again as r4078 at some point after
 this ticket was opened. And now that we have tests checking after the
 problem (and clearly PostGIS regresses fine too) I think this ticket can
 be closed.
Ticket URL: <https://trac.osgeo.org/geos/ticket/694#comment:8>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
