[geos-devel] [GEOS] #813: Port AppVeyor NMake builds to branches/3.6
GEOS geos-trac at osgeo.org
Sun Mar 26 10:21:04 PDT 2017
 Reporter:  Mateusz Łoskot  |       Owner:  geos-devel@…
     Type:  task            |      Status:  new
 Priority:  major           |   Milestone:  3.6.2
Component:  Default         |     Version:  svn-trunk
 Severity:  Unassigned      |  Resolution:
 Keywords:                  |
Description changed by Mateusz Łoskot:
Old description:
> May I merge this to branches/3.6 ?
> r4365 - !AppVeyor: Add x86 build using NMake
New description:
 * r4364 - Add step generating geos_svn_revision.h template with revision 0
 * r4365 - !AppVeyor: Add x86 build using NMake
Ticket URL: <https://trac.osgeo.org/geos/ticket/813#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
