[geos-devel] [GEOS] #813: Port AppVeyor NMake builds to branches/3.6
geos-trac at osgeo.org
Sun Mar 26 10:55:42 PDT 2017
Reporter: Mateusz Łoskot | Owner: geos-devel@…
Type: task | Status: new
Priority: major | Milestone: 3.6.2
Component: Default | Version: svn-trunk
Severity: Unassigned | Resolution:
Keywords: |
Description changed by Mateusz Łoskot:
Old description:
> May I merge this to branches/3.6 ?
> * r4364 - Add step generating geos_svn_revision.h template with revision
> 0
> * r4365 - !AppVeyor: Add x86 build using NMake
New description:
* r4364 - Add step generating geos_svn_revision.h template with revision 0
Or simply, sync trunk `appveyor.yml` with the one in branches/3.6.
Can I?
Ticket URL: <https://trac.osgeo.org/geos/ticket/813#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
