[geos-devel] [GEOS] #741: [PATCH] GEOSSimplify() returns empty polygon if inner ring dimension < simplify distance
geos-trac at osgeo.org
Tue Nov 28 00:32:17 PST 2017
simplify distance
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.6.1
Component: Default | Version: master
Severity: Unassigned | Resolution: fixed
Keywords: |
Comment (by Bas Couwenberg):
Replying to [comment:9 strk]:
> Done in trunk and 3.6 branch (for 3.6.1) - thanks
Can the change also be included in the 3.5 branch?
Ticket URL: <https://trac.osgeo.org/geos/ticket/741#comment:13>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
