[geos-devel] [GEOS] #741: [PATCH] GEOSSimplify() returns empty polygon if inner ring dimension < simplify distance
GEOS geos-trac at osgeo.org
Tue Nov 28 02:59:20 PST 2017
simplify distance
 Reporter:  rouault     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.6.1
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by strk):
 Could you prepare a patch for that ?
 Can be a pull request for the git
 repository (official hoster or any mirror).
Ticket URL: <https://trac.osgeo.org/geos/ticket/741#comment:15>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
