[geos-devel] [GEOS] #741: [PATCH] GEOSSimplify() returns empty polygon if inner ring dimension < simplify distance
geos-trac at osgeo.org
Tue Nov 28 09:46:18 PST 2017
simplify distance
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.6.1
Component: Default | Version: master
Severity: Unassigned | Resolution: fixed
Keywords: |
Comment (by Bas Couwenberg <sebastic@…>):
In [changeset:"710ddbe48177c215f98dd5e90fb64460b35401a7/git" 710ddbe/git]:
#!CommitTicketReference repository="git"
revision="710ddbe48177c215f98dd5e90fb64460b35401a7"
Fix empty GEOSSimplify return on inner ring collapse
Patch by Even Rouault
See #741
git-svn-id: http://svn.osgeo.org/geos/trunk@4311 5242fede-
7e19-0410-aef8-94bd7d2200fb
Ticket URL: <https://trac.osgeo.org/geos/ticket/741#comment:16>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
