[geos-devel] MOTION to accept this patch [geos] Emit a warning at compile time about C++ API being unstable (#14)
Sandro Santilli strk at kbt.io
Wed Oct 4 08:26:19 PDT 2017
On Wed, Oct 04, 2017 at 10:39:08AM -0400, Regina Obe wrote:
> Can all PSC folks vote if this is agreeable.  This will be done for GEOS 3.7 and above.
> Feedback from others is welcome as well.
> This  GEOS patch will display a warning in the Geometry.h header which appears during compile time whenever the C++ API is used to compile a projects source, unless
> WE_ACKNOWLEDGE_THAT_THE_GEOS_CPLUSPLUS_API_IS_UNSTABLE
> Is defined?
> https://git.osgeo.org/gogs/geos/geos/pulls/14
> +1
+1, ofc (next step would be turning that warning into an error)
--strk;
