[geos-devel] GEOS 3.7.0 beta end this week
Sandro Santilli strk at kbt.io
Sun Sep 10 01:15:02 PDT 2017
On Sat, Sep 09, 2017 at 07:37:28PM -0400, Regina Obe wrote:
> Regarding the hooks.  Manually triggering them works.  Can you verify you are calling the hooks.  Your hook code looks okay.
The hook had syntax errors, now it should be ok, but it suffers
from another problem:
Problem accessing
/view/GEOS/job/GEOS_Branch_hooks/buildWithParameters.
Reason: Not Found
That means the hook script cannot be generic unless you turn
the branch name in to a parameter instead of part of the URI.
BTW: /view/GEOS/job/GEOS_Master/buildWithParameters exists
     /view/GEOS/job/GEOS_Branch_3.6/buildWithParameters does not
shouldn't it exist ?
--strk;
