[geos-devel] [GEOS] #712: Single-sided buffer gives unexpected result
geos-trac at osgeo.org
Fri Sep 15 09:19:26 PDT 2017
Reporter: pmeems | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.6.3
Component: Default | Version: 3.4.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
Pretty likely that JTS gives the same result.
There's a lot of heuristics in the buffer code, intended to give stable
and correct results for all of the various ways in which it can be
parameterized (but with priority given to the primary use case of round
buffers). It might be possible to improve the heuristics to get better
results in this situation, but it will require either extensive testing to
ensure no regression in all other buffer situations, or a different code
path provided for just Single-Sided Buffer.
Ticket URL: <https://trac.osgeo.org/geos/ticket/712#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
