[geos-devel] [GEOS] #712: Single-sided buffer gives unexpected result
GEOS geos-trac at osgeo.org
Mon Sep 18 00:09:40 PDT 2017
 Reporter:  pmeems      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.6.3
Component:  Default     |     Version:  3.4.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by jrkleemann):
 JTS has pretty much the same code, so it should provide the same result.
Ticket URL: <https://trac.osgeo.org/geos/ticket/712#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
