[geos-devel] [GEOS] #912: bintree::Bintree API hides implementation and leads to SEGFAULT.
GEOS geos-trac at osgeo.org
Mon Aug 13 10:07:46 PDT 2018
 Reporter:  basiliscos  |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:
Component:  Default     |    Version:  3.6.2
 Severity:  Unassigned  |   Keywords:
 Bintree::insert (Interval *itemInterval, void *item) states
 Parameters
 itemInterval    Ownership left to caller, NO reference hold by this class.
     item        Ownership left to caller, reference kept by this class.
 In implementation it leads to
 root->insert(insertInterval,item);
 void NodeBase::add(void* item){
         items->push_back(item);
 and in the destructor of NodeBase
 NodeBase::~NodeBase() {
         for(int i=0;i<(int)items->size();i++) {
                 delete (MonotoneChain*)(*items)[i];
 it, first, casts to '''MonotoneChain''' (i.e. it violates void* contract),
 and, second, it invokes destructor, i.e. opposite to what is stated in
 documentation about item ownership.
 Please, fix.
Ticket URL: <https://trac.osgeo.org/geos/ticket/912>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
